This started 2 months ago. I used to be able to open the full interface on octoprint with firefox. Now, when I click on the control tab it locks it up and if I change tabs on firefox and come back to octoprint it just shows me the loading wheel for firefox. I am unsure of what has changed.
Starting an inprivate session seems to fix the problem. Removing all extensions/plugins does not. I have no problems in Chrome or in Konqueror. I have uninstalled firefox and reinstalled it with the no change. Ocotprint loads fine on the other 2 gui browsers I have loaded on this machine, so I know that it has to be a mozilla problem.
No need to run in safe mode as it works properly on other browsers.
Update: Same issue exists in safe mode
Not required to test in safe mode
Update: No
browser.user_agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/534.34 (KHTML, like Gecko) konqueror/20.12.3 Safari/534.34
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 917016576
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopi_version: 0.17.0
env.plugins.pi_support.throttle_state: 0x80000
env.python.pip: 21.3.1
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.safe_mode: False
octoprint.version: 1.7.2
systeminfo.generator: zipapi
Octoprint 1.7.2
browser is firefox 94.0 (64-bit)
OS Pop!_OS 21.04
