Could not acces octoprint with hostname
I can acces to my octoprint instance with the IP adress of my raspberry with 192.168.xx.xx:5000. Bit my IP isn't fixed so I would like to acces to octoprint with the hostname. For now I didn't change the hostname, it's still raspberrypi. When I try to connect with raspberrypi.local:5000, it won't work.
I tried to setup avahi with this tuto [Setting up OctoPrint on a Raspberry Pi running Raspbian] at the section" Optional: Reach your printer by typing its name in address bar of your browser - Avahi/zeroconf/bonjour-based" but didn't worked.
I also tried [http://elinux.org/RPi_Advanced_Setup#Setting_up_for_remote_access_.2F_headless_operation] section "The flexible way: set up avahi / zeroconf"(
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
I installed Octoprint with this tuto : Setting up OctoPrint on a Raspberry Pi running Raspbian
Simplest way is to add a hosts file entry for the Octoprint server. If you are running your own DNS, you could also add it there....
Try this one and see if it helps.
What type of computer are you trying to use to access your Pi? By default, Windows does not include Ahavi / Zeroconf / Bonjour.
I tried with a windows PC, a Linux Virtual Machine on my PC and also a MAC but it works on any of those
The weird thing is that I first installed octopi and it worked, I could access with octopi.local.
But now I want to build from the sources of octoprint so I installed raspbian lite and octoprint directly from github.
Since it worked with octopi, I don't think it's a probelm from the computer I use to access mi Pi
Have you tried just http://raspberrypi:5000 ?
That's what I use. (well other hostname but still without .local)
