My Printer is a i3 mini
it was always working until one day i turned the printer off because of no filement
octoprint.version: 1.8.6
browser.user_agent: Mozilla/5.0 (X11; Linux x86_64; rv:108.0) Gecko/20100101 Firefox/108.0
connectivity.enabled: False
connectivity.online: True
env.hardware.cores: 1
env.hardware.freq: 700.0
env.hardware.ram: 384393216
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi Model B Rev 2
env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.8.6-20221018093204
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2023-01-11T09:04:16Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: True
systeminfo.generated: 2023-01-11T09:19:30Z
systeminfo.generator: zipapi
2023-01-11 07:15:39,500 - octoprint.startup - INFO - Starting OctoPrint 1.8.6
2023-01-11 07:15:39,502 - octoprint.startup - INFO - ******************************************************************************
2023-01-11 07:17:59,896 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 384393216
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| throttle_check_enabled: true
| throttle_check_functional: true
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
2023-01-11 08:47:09,523 - octoprint.util.comm - WARNING - Received line:
2023-01-11 08:47:09,569 - octoprint.util.comm - WARNING - | øùNp|<b6T=BpOB6JK%øovTEPMj].6bxqÐXø@áJðfðY6]7ð%Iþ%ÞB6~_&eðC'8Vô=ªaJ%øaÁA@áJ´cøeÁEáYp|"EeXe6P.`p|,]öfáJJ@áHX6ráB¸JJ B8CJ?XBp|4fXFüeÉ8p|$þAJÿQJJ¿TJpp8n\x00éeN>heÉbváBZäAÿQú%hQée^:heÉbCa?.mCP..aKCa.a+JBøBJüJB%TJptXOaÚ:]"eØ:O&M&eÚ6íeAoYÔ6f\ac2>Ke23BJAÐzøB(%(%0ÖJXá"Mi2aBRI¸rN@áe|O6p| PAváB%X¤(%rJpp¸AJ'AJ!A!JrJp|°AB'I2"66|"Ne^fñJ¤C BA ¸K² B-H2a
2023-01-11 08:47:09,662 - octoprint.util.comm - WARNING - The received line contains at least one null byte character at position 202, this hints at some data corruption going on
2023-01-11 08:47:42,907 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 08:47:52,954 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2023-01-11 09:02:53,443 - octoprint.server.api.system - INFO - Performing command for core:restart_safe: sudo service octoprint restart
2023-01-11 09:02:55,581 - octoprint.server - INFO - Shutting down...
2023-01-11 09:02:55,992 - octoprint.server.api.system - WARNING - Command for core:restart_safe failed with return code -15:
! STDOUT:
! STDERR:
2023-01-11 09:02:56,617 - octoprint.server - INFO - Calling on_shutdown on plugins
2023-01-11 09:02:56,631 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2023-01-11 09:02:56,798 - octoprint.events - INFO - Event loop shut down
2023-01-11 09:02:57,337 - octoprint.server - INFO - Goodbye!
2023-01-11 09:03:21,552 - octoprint.startup - INFO - ******************************************************************************
2023-01-11 09:03:21,630 - octoprint.startup - INFO - Starting OctoPrint 1.8.6
2023-01-11 09:03:21,631 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2023-01-11 09:03:21,633 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2023-01-11 09:03:21,635 - octoprint.startup - INFO - ******************************************************************************
2023-01-11 09:03:26,341 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2023-01-11 09:03:26,346 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2023-01-11 09:03:26,347 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2023-01-11 09:03:27,249 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)
2023-01-11 09:03:27,354 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2023-01-11 09:04:14,179 - octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 38 hook handlers
2023-01-11 09:04:16,095 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2023-01-11 09:04:17,143 - octoprint.server - INFO - Intermediary server started
2023-01-11 09:04:17,515 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2023-01-11 09:04:17,532 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2023-01-11 09:04:17,583 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
2023-01-11 09:04:17,587 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
2023-01-11 09:04:17,603 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2023-01-11 09:04:17,623 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2023-01-11 09:04:17,633 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")
2023-01-11 09:04:17,647 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2023-01-11 09:04:17,658 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_GRANT (needs: "Need(method='role', value='plugin_appkeys_user')")
2023-01-11 09:04:17,675 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2023-01-11 09:04:17,693 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
2023-01-11 09:04:17,707 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2023-01-11 09:04:17,723 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2023-01-11 09:04:17,794 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_LIST (needs: "Need(method='role', value='plugin_pluginmanager_list')")
2023-01-11 09:04:17,802 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2023-01-11 09:04:17,861 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_install'), Need(method='role', value='plugin_pluginmanager_manage')")
2023-01-11 09:04:17,883 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2023-01-11 09:04:17,920 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2023-01-11 09:04:17,942 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
2023-01-11 09:04:29,375 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2023-01-11 09:04:38,009 - octoprint.util.pip - INFO - Version of pip is 20.3.3
2023-01-11 09:04:38,185 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2023-01-11 09:04:38,187 - octoprint.util.pip - INFO - ==> pip ok -> yes
2023-01-11 09:04:39,611 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2023-01-11 09:04:39,992 - octoprint.plugin.core - INFO - Initialized 18 plugin implementation(s)
2023-01-11 09:04:40,202 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| Event Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/eventmanager
| File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| Firmware Check (2021.10.11) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Pi Support Plugin (2022.6.13) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2023-01-11 09:04:40,504 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 384393216
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| python:
| pip: 20.3.3
| version: 3.7.3
2023-01-11 09:04:40,724 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2023-01-11 09:04:40,754 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2023-01-11 09:04:40,775 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-manifest.json...
2023-01-11 09:04:48,203 - octoprint.server - INFO - Shutting down intermediary server...
2023-01-11 09:04:48,356 - octoprint.server - INFO - Intermediary server shut down
2023-01-11 09:04:48,386 - octoprint.events - INFO - Processing startup event, this is our first event
2023-01-11 09:04:48,390 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2023-01-11 09:04:48,440 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2023-01-11 09:04:48,462 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2023-01-11 09:04:48,490 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2023-01-11 09:04:48,510 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2023-01-11 09:04:49,555 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2023-01-11 09:04:50,666 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2023-01-11 09:04:50,736 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2023-01-11 09:04:50,939 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2023-01-11 09:04:50,957 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2023-01-11 09:04:52,138 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2023-01-11 09:04:57,877 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.165
2023-01-11 09:04:59,350 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.165
2023-01-11 09:05:00,371 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.165
2023-01-11 09:05:15,367 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2023-01-11 09:05:17,303 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2023-01-11 09:05:17,359 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2023-01-11 09:05:17,385 - octoprint.util.pip - INFO - ==> pip ok -> yes
2023-01-11 09:05:17,806 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 12.0GB. That is considered sufficient for updating.
2023-01-11 09:05:22,214 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.165
2023-01-11 09:05:23,802 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'https://192.168.178.220/', 'path': '/', 'query_string': 'l10n=en'}
2023-01-11 09:05:57,346 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2023-01-11 09:06:02,980 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.165
2023-01-11 09:06:03,855 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.165
2023-01-11 09:06:09,481 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.165
2023-01-11 09:07:42,208 - octoprint.server.preemptive_cache - INFO - ... done in 138.41s
2023-01-11 09:07:42,222 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui default) for {'base_url': 'http://192.168.178.220/', 'path': '/', 'query_string': 'l10n=en'}
2023-01-11 09:07:51,068 - octoprint.server.preemptive_cache - INFO - ... done in 8.85s
2023-01-11 09:11:36,270 - octoprint.access.users - INFO - Logged in user: pi
2023-01-11 09:11:36,316 - octoprint.server.api - INFO - Actively logging in user pi from ::ffff:192.168.178.165
2023-01-11 09:11:36,616 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.165
2023-01-11 09:11:37,005 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.165
2023-01-11 09:11:37,008 - octoprint.access.users - INFO - Logged in user: pi
2023-01-11 09:11:38,446 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.165
2023-01-11 09:11:38,723 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.165
2023-01-11 09:11:42,403 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.165
2023-01-11 09:11:42,677 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.178.165
2023-01-11 09:11:42,681 - octoprint.access.users - INFO - Logged in user: pi
2023-01-11 09:11:55,862 - octoprint.server.util.sockjs - INFO - User pi logged in on the socket from client ::ffff:192.168.178.165
2023-01-11 09:12:07,174 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2023-01-11 09:12:07,445 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2023-01-11 09:12:07,448 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2023-01-11 09:12:07,494 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2023-01-11 09:12:07,622 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2023-01-11 09:12:07,667 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:09,797 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2023-01-11 09:12:09,855 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:11,926 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2023-01-11 09:12:12,052 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:14,133 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 250000
2023-01-11 09:12:14,187 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2023-01-11 09:12:14,228 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:16,313 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2023-01-11 09:12:16,432 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:18,454 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2023-01-11 09:12:18,546 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:20,641 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 230400
2023-01-11 09:12:20,742 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2023-01-11 09:12:20,873 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:22,908 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2023-01-11 09:12:23,003 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:25,031 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2023-01-11 09:12:25,083 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:27,123 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 57600
2023-01-11 09:12:27,195 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2023-01-11 09:12:27,252 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:29,297 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2023-01-11 09:12:29,350 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:31,363 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2023-01-11 09:12:31,416 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:33,436 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 38400
2023-01-11 09:12:33,532 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2023-01-11 09:12:33,607 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:35,675 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2023-01-11 09:12:35,706 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:37,733 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2023-01-11 09:12:37,755 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:39,828 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 19200
2023-01-11 09:12:39,891 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2023-01-11 09:12:39,983 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:42,010 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2023-01-11 09:12:42,048 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:44,069 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2023-01-11 09:12:44,124 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:46,139 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 9600
2023-01-11 09:12:46,175 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2023-01-11 09:12:46,214 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:48,233 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2023-01-11 09:12:48,333 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:50,386 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2023-01-11 09:12:50,453 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:12:52,498 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error"
2023-01-11 09:12:52,592 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2023-01-11 09:12:52,714 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2023-01-11 09:13:05,549 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2023-01-11 09:13:05,752 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2023-01-11 09:13:06,018 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2023-01-11 09:13:06,340 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:13:49,215 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:13:59,358 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2023-01-11 09:13:59,561 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2023-01-11 09:17:06,307 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2023-01-11 09:17:06,544 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2023-01-11 09:17:06,851 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2023-01-11 09:17:07,235 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:17:16,755 - octoprint.util.comm - WARNING - Received line:
2023-01-11 09:17:16,758 - octoprint.util.comm - WARNING - | øñNpt8n>X5JpGN&BC)hàorLAPMzQ>2npyØPðHáBô~èQ\x00>U'ø%Qþ)ÚF:zS.üK'0^ü-²J!èeÁE@áJ¤kðmÁMláApp:MeX6P.dp|$]òráBJ@áHX6váB¼JJ B8CJ?XBp|4fHFìeÉ8p|$úAJÿAJJ¿TJpp8n\x00éeN>heÉbváBZäQÿQú%hQéeN:heÉbKa7mKP..aKCa.a;JBüBJüJB%HJppXOaÞ6M6eÜ6.E&eÒ6áMgYÜ2~Lec6>Ke&;JBIØrüJ(% !(ÎB@á]m2BZA°zBHá"tG6tt,@IfáJ%T¼ %zBp|°AB/I2B%P¤ AjBp|°AJ/A:a&6x&B.VváB¼[ JE ¼[¢(J-P:
2023-01-11 09:17:16,788 - octoprint.util.comm - WARNING - The received line contains at least one null byte character at position 60, this hints at some data corruption going on
2023-01-11 09:17:50,186 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2023-01-11 09:18:00,268 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2023-01-11 09:18:00,372 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2023-01-11 09:19:16,124 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-01-11 09:19:29,946 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.165
