2021-02-23T05:00:00Z
I installed a CanaKit Raspberry Pi.
After doing all the set-up with the OctoPrint software it will not print to my bed size.
300mm x 300mm x 400mm instead it prints in a corner and if the print is larger than 60mm x 60mm
it tells me my model is to big. When I hit print it goes thru the auto level on the full bed.
I'm printing from my mobile workstation because I can't connect with my iPhone. I use Cura to do my slicing and that shows my full print bed and it has worked great. Any help would be appreciated.
