CR 10S Pro V2 'serial' in section 'mcu' must be specified
EDIT: I started over with a fresh install of Octoprint without Klipper. Still having issues but made another post. I don't see how to delete this post.
Initial setup won't print a working g-code file from Cura. Error: Your printer's firmware reported an error. Due to that the ongoing print job will be cancelled. Reported error: Option 'serial' in section 'mcu' must be specified
I looked for a place to specify the serial and looked on the forum for the correct profile for my printer
No, I don't know how to run in safe mode
OctoPrint version Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.4, * OctoKlipper: AGPLv3 OctoPi version, printer Creality CR 10S V2, Creality firmware, Brave browser, Firefox browser, Windows 10
octoprint-systeminfo-20221211123215.zip (208.9 KB)
operating system, ... as much data as possible
Hint: blue words a links :wink:
You are running Klipper.
Please consult the Klipper forum:
If you didn't intend to install Klipper, which you have done, then you've installed the wrong OS image - choose just OctoPi rather than OctoKlipper. If you did want to install Klipper then don't forget that there's a lot more configuration and installation that has to be done to build the firmware for your printer first, which you can find on the Klipper website.
Thanks, I reflashed with just Octopi. Didn't know that Klipper would interfere with Octopi. Still not quite working but I will do some reading before posting again
