When I want to print any part the printer starts to do the automatic leveling but after doing the X / Y Home it starts doing the Z Home and the Z axis just goes up and does not stop going up instead of going down as it does Normally, if I do not connect it to Octoprint and if I do not turn off the printer manually, the Z axis goes off the rails. Could you please tell me if I am the only one to whom this happens?
I leave the snippet of text that I see in the "terminal" of octoprint if you see any error there.
thank you!!
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
Octoprint Terminal log :
Recv: ==T:200.00 /200.00 ==B:60.10 /60.00 @:54 B@:127
Changing monitoring state from "Operational" to "Starting"
Send: N0 M110 N0*125
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 M140 S50*81
Recv: ok
Recv: ok ==T:200.00 /200.00 ==B:60.16 /50.00 @:54 B@:127
Send: N3 M190 S50*94
Recv: ok
Send: N4 M104 S200*99
Recv: ok
Send: N6 M109 S200*108
Recv: ==T:200.00 /200.00 ==B:60.19 /50.00 @:54 B@:127 W:?
Recv: ok
Send: N7 M82*30
Recv: ok
Send: N8 M201 X500.00 Y500.00 Z100.00 E5000.00*2
Recv: ok
Send: N9 M203 X500.00 Y500.00 Z10.00 E50.00*49
Recv: ok
Send: N10 M204 P500.00 R1000.00 T500.00*77
Recv: Setting Print Acceleration: 500.00
Recv: Setting Retract Acceleration: 1000.00
Recv: Setting Travel Acceleration: 500.00
Recv: ok
Send: N11 M205 X8.00 Y8.00 Z0.40 E5.00*11
Recv: ok
Send: N12 M220 S100*82
Recv: ok
Send: N13 M221 S100*82
Recv: ok
Send: N14 G28*38
Recv: ==T:200.28 /200.00 ==B:60.43 /50.00 @:49 B@:127
Recv: echo:busy: processing
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
The command "Recv: echo:busy: processing" is because I have to turn off the printer y that moment
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
OctoPrint version : OctoPrint 1.3.11 running on OctoPi 0.16.0
Printer : CR10S PRO
