I have connected OctoPrint to my Creality CR10 Max. I was able to send a G-code command to understand the firmware settings. Here it is.
Send: M503
Recv: echo: G21 ; Units in mm
Recv: echo: M149 C ; Units in Celsius
Recv:
Recv: echo:Filament settings: Disabled
Recv: echo: M200 D1.75
Recv: echo: M200 D0
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z400.00 E140.00
Recv: echo:Maximum feedrates (units/s):
Recv: echo: M203 X500.00 Y500.00 Z10.00 E50.00
Recv: echo:Maximum Acceleration (units/s2):
Recv: echo: M201 X500 Y500 Z100 E5000
Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv: echo: M204 P500.00 R1000.00 T500.00
Recv: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
Recv: echo: M205 S0.00 T0.00 B20000 X8.00 Y8.00 Z0.40 E5.00
Recv: echo:Home offset:
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:Auto Bed Leveling:
Recv: echo: M420 S1 Z0.00
Recv: echo:PID settings:
Recv: echo: M301 P30.86 I3.10 D75.84
Recv: echo:Z-Probe Offset (mm):
Recv: echo: M851 Z-1.70
Recv: ok
I also get lots of connection status messages in the log.
I uploaded a gcode file to print. That seemed to work fine. But when I tried to print, it sat for a while and then both OctoPrint and the printer itself reported an error that it did not heat ("Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!").
I reloaded the file and tried again.
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
Here is a bit more from the log.
Changing monitoring state from "Operational" to "Starting"
Send: N0 M110 N0125
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 M140 S5081
Recv: ok
Send: N2 M10537
Recv: ok == T:24.14 /0.00 == B:24.30 /50.00 @:0 B@:0
Send: N3 M190 S5094
Recv: == T:24.14 /0.00 == B:24.30 /50.00 @:0 B@:0 W:?
Recv: == T:24.02 /0.00 == B:24.37 /50.00 @:0 B@:0
Recv: == T:24.22 /0.00 == B:24.45 /50.00 @:0 B@:127 W:?
Recv: echo:busy: processing
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
Recv: Error:Heating failed, system stopped! Heater_ID: bed
Recv: Error:Printer halted. kill() called!
Changing monitoring state from "Printing" to "Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!"
Changing monitoring state from "Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!" to "Offline (Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!)"
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
OctoPrint 1.3.11
OctoPi Version 0.16.0, running on Raspberry Pi 3 Model B Rev 1.2
CR-10 Max Firmware Ver 1.70.0 BL
