Hi and thanks for having me. Ill try to be good. I'm completely new to 3D printing but have some CNC experience.
The creality cr-100 is a little toy and is currently a discontinued item for $A300 at Jaycar. Made for kids and dressed up like a little truck complete with exhaust stacks. No luxuries like bedwarming etc but the magnetic self levelling bed makes it easy to unload prints.
Prints gcode produced by slic3r faultlessly from the SD card. The TF card supplied with the machine was a POC which took a few frustrating hours to figure out.
Hooking it up to my rpi 3B+ running Octoprint the settings are Marlin firmware, 115200bps this happens:
I unplugged the printer from the Octoprint machine and plugged into my other rpi running printrun pronterface. Everything now seemed to work correctly. I was able to print live but with some odd quirks. The printer would only do one block at a time. I had to press pause and resume to get pronterface to send the next block the the printer.
I can post some pronterface logs if anyone is interested.
OCTOPRINT TERMINAL:
Send: N0 M110 N0*125
Recv: ok
Send: N1 M115*39
Recv: Firmware_Name:BiSun
Recv: Firmware_Url:https://www.cxsw3d.com
Recv: Firmware_Ver:0.1.6
Recv: Machine_Name:CR-100
Recv: Head_Count:1
Recv: ok
Send: N2 M21*18
Recv: Echo:SD Card ok
Recv: ok
Send: N3 M105*36
Recv: Echo:Get Head(0) T:20.7/0.0
Send: N4 M105*35
Recv: Echo:Get Head(0) T:20.5/0.0
Send: N5 M105*34
Recv: Echo:Get Head(0) T:20.6/0.0
Send: N6 M105*33
Recv: Echo:Get Head(0) T:20.4/0.0
Send: N7 M105*32
Recv: Echo:Get Head(0) T:21.0/0.0
Send: N8 M105*47
Send: N9 M105*46
Recv: Echo:Get Head(0) T:21.2/0.0
Send: N10 M105*22
Send: N11 G91*33
Recv: ok
Send: N12 G1 Z10 F200*52
Recv: ok
Send: N13 G90*34
Recv: ok
Send: N14 G91*36
Recv: ok
Send: N15 G1 X-10 F6000*40
Recv: ok
Send: N16 G90*39
Recv: ok
Send: N17 M105*17
Recv: Echo:Get Head(0) T:21.1/0.0
Send: N18 M105*30
Send: N19 M105*31
OctoPrint v1.4.0
Octopi 0.17.0
kernel 4.19.97-v7+
