Octoprint is unable to connect to my CR-6 SE
I can see the Octopi / Octoprint on my network and connect to it. I am not able to connect to the CR-6 SE to Octoprint. I also have a webcam that is working properly.
I have updated the firmware/App for Octoprint/OctoPi.
I have upgraded from 1.4.3 to 2.0.13
Based on what I am seeing and my understanding, the usb port I am connecting to on the printer will not allow a serial connection. I have tried multiple cables. I have noticed that the MicroUSB connection will power the LCD panel if the printer is powered off but would not think that is the issue. No I have not tried to isolate the +5 on the USB...
Yes
No it did not
Complete Logs
When I try to connect I am getting the Following error in the browser:
State: Offline (Error: Could not write to serial port)
Syslog shows the following:
Jan 5 01:09:07 octopi kernel: [82590.950230] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
Jan 5 01:09:07 octopi kernel: [82591.083322] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
Jan 5 01:09:07 octopi kernel: [82591.083338] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Jan 5 01:09:07 octopi kernel: [82591.083348] usb 1-1.5: Product: USB Serial
Jan 5 01:09:07 octopi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5"
Jan 5 01:09:07 octopi mtp-probe: bus: 1, device: 5 was not an MTP device
Jan 5 01:09:07 octopi kernel: [82591.164192] usbcore: registered new interface driver usbserial_generic
Jan 5 01:09:07 octopi kernel: [82591.164263] usbserial: USB Serial support registered for generic
Jan 5 01:09:07 octopi kernel: [82591.167864] usbcore: registered new interface driver ch341
Jan 5 01:09:07 octopi kernel: [82591.167952] usbserial: USB Serial support registered for ch341-uart
Jan 5 01:09:07 octopi kernel: [82591.168090] ch341 1-1.5:1.0: ch341-uart converter detected
Jan 5 01:09:07 octopi kernel: [82591.170356] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
Jan 5 01:10:39 octopi kernel: [82683.068303] usb 1-1.5: USB disconnect, device number 5
Jan 5 01:10:39 octopi kernel: [82683.069085] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
Jan 5 01:10:39 octopi kernel: [82683.069186] ch341 1-1.5:1.0: device disconnected
And the Serial log shows:
2021-01-05 15:48:46,080 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyAMA0@115200, /dev/ttyAMA0@250000, /dev/ttyAMA0@230400, /dev/ttyAMA0@57600, /dev/ttyAMA0@38400, /dev/ttyAMA0@19200, /dev/ttyAMA0@9600
2021-01-05 15:48:46,082 - Trying port /dev/ttyAMA0, baudrate 115200
2021-01-05 15:48:46,087 - Connecting to port /dev/ttyAMA0, baudrate 115200
2021-01-05 15:48:46,104 - Handshake attempt #1 with timeout 2.0s
2021-01-05 15:48:47,152 - Could not write anything to the serial port in 5 tries, something appears to be wrong with the printer communication
2021-01-05 15:48:47,159 - Changing monitoring state from "Detecting serial connection" to "Offline (Error: Could not write to serial port)"
2021-01-05 15:48:47,169 - Closing down send loop
serial (5).log (1.7 KB)
octoprint.log (241.8 KB) syslog.log (151.2 KB)
Latest versions of Octoprint / Octopi
Firmware for the CR-6 SE. 2.0.1.3
MacOS 11.0. Using Chrome
