My printer will NOT connect to my computer, octoprint and won't show up in serial port menu
using different cables reflashing both firmwares
I am using Marlin 1.1.9 with bootloader and bltouch installed.
Latest Octoprint version.
Only a temporary setup so no camera connected
Help Me please I have been trying to fix this for WEEKS!
Just to be sure - your printer also doesn't work on your pc with pronterface or something similar?
HELP
Also I have the Creality 1.1.5 mainboard
When I try to flash firmware with arduino the com port will not show up and keeps giving error
How did you flash the firmware and which firmware did you use exactly?
Marlin 1.1.9 and i flashed it using arduino ide through the isp
because i couldn't through the usb
I see.
Does the printer itself work? Does it boot up and show something on the display?
Yes everything else works fine even the sd card
Well then I guess either the usb port is broken or something is wrong with the firmware.
Let's look at the firmware. Zip the Configuration.h and Configuration_adv.h you used and upload them here.
It WAS working before then it just stopped
The new firmware worked and then it just stopped?
Well then I'm pretty sure something is wrong with the usb.
I don't see anything wrong with the config. You didn't select the tmc2208s as drivers but that's not that important.
is there a way to connect to the pi not using usb (idk)?
The printer still turns on with out the main power supply when connected to the usb so maby??
No sry. This board got no uart
Maybe you can see a bent pin inside the port or a broken solder joint on the pcb.
I suggest you wait a day and see if anyone alse got an idea.
Thanks I fixed by pulling out a bent pin inside of the plug
