Creamer will disapear and reapear
Creative Live
The camera will continue to disappear, the camera will come up when Octoprint starts but will disappear within a minute or two, then at times it will come back for a few minutes then disappear. If I log out them back in it will do the same, at times it will come back by refreshing (not every time) but will disappear again
I am a newbie and lost with this
I cannot find the Log
Hello @glenncol !
Please:
Blue words are links for more information.
In this case, please also share the systeminfo bundle.
Hi, thank you, i have attached the file
octoprint-systeminfo-20230426162330.zip (103.0 KB)
It appears you are not running on a Raspberry Pi, I had to search for that information.
The Enclosure plugin will not work on other hardware.
The same is for GPIOcontrol and Octorelay
You should delete them from your plugin list.
Hi, thank you, i shoul dhave mentioned that i am running Unbuntu on a Intel NUC with Octoprint.
I will delete them right away
I just looked at the plugins list and they are not installed but i do recall installing them
How and what did you install for your webcam streaming?
You should get them deleted in OctoPrint's safe mode
Hi, i used Paul Stelis script and used Ustreamer as the streamer
Hi Ewald, i logged in via Safe mode and found those plugins and they have now been removed, thank you
I will see how it goes (Update still has the same issue)
