Printer: CTC Bizer (2560 chip)
Slicer: Cura (latest Version)
Error occured straight AFTER flashing
sailfish7.7
FW.
Everything worked well on stock 7.4 FW
Printing from SD Card with Cura Gcode converted to .x3g works flawless.
When I click on Print:
- extruder / bed is NOT heating
- steppers are making a sound (like when printing)
- printhead stays in the home corner
- printhead is moving very very slow, less than 1mm / s
At some point this problem dissappeared and magically appeared again. ( I didnt really change any thing)
I tried to make sure all GPX and ocotPrint settings are correct.
I upgraded my Ocotprint and Plugisn to the latest version.
Tried different Start gcodes and veriefied they are working (sd card print works fine.)
I'm not really sure which Info I need to provide. I will provide everything you need, just tell me
OctoPrint 1.4.0 auf OctoPi 0.12.0
GPX Plugin : 2.6.2
Update:
I only use the right extruder. Yes GPX is installed, maybe I do not have the right settings. In Cura and Octoprint I selected Replicator 1.
The homing on the printer itself works also when print from sd card.
I will try to attach my GPX / Octoprint settings as well.
In octoprint I'm not able to control my printhead not via the buttons nor via the Terminal G Codes. Sometimes it starts making some noise but its not moving correctly / at all.
;{material_bed_temperature_layer_0} = Temperatur der Druckplatte für die erste Schicht
;Erzeugt am: {day} {date} {time} = Infoanzeige von Datum im Gcode an dem der Gcode erzeugt wurde
;{material_print_temperature_layer_0} = Drucktemperatur für erste Schicht (Materialtemp.)
;Material-Flow: {material_flow}% = Info über den gewählten Material-Flow
(**** start.gcode for The Replicator, dual head ****)
M103 (disable RPM)
M73 P0 (enable build progress)
G21 (set units to mm)
G90 (set positioning to absolute)
M140 S{material_bed_temperature_layer_0} (set HBP temperature)
M104 S{material_print_temperature_layer_0} T0 (set right extruder temperature)
(**** begin homing ****)
G162 X Y F2500 (home XY axes maximum)
G161 Z F1100 (home Z axis minimum)
G92 Z-5 (set Z to -5)
G1 Z0.0 (move Z to "0")
G161 Z F100 (home Z axis minimum)
M132 X Y Z A B (Recall stored home offsets for XYZAB axis)
(**** end homing ****)
G1 X-110.5 Y-74 Z150 F3300.0 (move to waiting position)
G130 X20 Y20 Z20 A20 B20 (Lower stepper Vrefs while heating)
(* M18 ( Disable stepper motors to allow user to move head before printing starts ) *)
M6 T0 (wait for toolhead, and HBP to reach temperature)
G130 X127 Y127 Z40 A127 B127 (Set Stepper motor Vref to defaults)
M108 R5.0 T0 (Set Extruder Speed)
G0 X-110.5 Y-74 (Position Nozzle)
G0 Z0.6 (Position Height)
M101 (Start Extruder)
G4 P2000 (Create Anchor)
(**** end of start.gcode for The Replicator, dual head ****)
M73 P100 ( End build progress )
G0 Z150 ( Send Z axis to bottom of machine )
M18 ( Disable steppers )
M109 S0 T0 ( Cool down the build platform )
M104 S0 T0 ( Cool down the Right Extruder )
M104 S0 T1 ( Cool down the Left Extruder )
G162 X Y F2500 ( Home XY endstops )
M18 ( Disable stepper motors )
M70 P5 ( We <3 Making Things!)
M72 P1 ( Play Ta-Da song )
Logs:
plugin_GPX.log (60.8 KB) octoprint.log (13.9 KB)
