From today, CR10S Pro pause itself every few moves,
After enquiring it was always when extruder temp was "low" (I mean below 204.5 C° when terget is 205 C°) and restarded when temperature was high and above 205.5 C°
I PID the printer to tune it up, value did not change much, printer is still pausing
I am on CR10S-Pro with Minifactory B6 firmware, Raspberry Pi 3B+. I have been running this printer daily for months on that setup without issue, and did not change much
Why is your GCODE interspersed with M204/change acceleration commands? That looks fishy.
And what does "the printer pauses itself" mean. Do you actually have to hit a button on the controller or does it just stop moving and then continue on its own?
It pause itself when temperature is "low" meaning under 0.5 C° below the targeted temperature and then resume print on its own when temperature is above 0.5C° targeted temperature
I use to programme in Gcode Long time ago on industrial heavy machinery (Airbus).
I was wondering if there is not a bracketing security value if the temperature goes out of the bracketed set temperature value then pause to go back to the bracket value like temperature (T=205 (+) or (-) 0.5C°) so below 204.5 and above 205.5 the printer will pause to go back with bracket ?
I will try to flash the Tiny machie firmaware B6 version again in case it was this, I upgraded 2 weeks ago, but printed a lot since then without any issues
Oh my gosh. I just had the exact same issue! Do you know what's different with the Cura 4.1 gcode that is causing the pauses? Mine ran fine for an hour+, then started doing a LOT of pauses. Somewhere around 25 seconds each. In my case, half of that was after it finished a section of my print, then it would G0 move to the next section and pause for the other "half" of the 25 seconds, then print the next section (repeat...) I finally had to kill it for fear of something wrong with my 3D printer...
Now I see it's probably Cura 4.1. I will revert back and try it again later.
