Octoprint Plugin option missing after I sliced I only had the option to "save file". Figured it must have had something to do with me reflashing octopi. Couldn't find Octoprint connection option under "Manage printer" in Cura. So I uninstalled plugin and tried again twice without luck.
I tried to reinstall the Octoprint plugin. Twice.
n/a
n/a
Complete Logs
Of course you can ask this question here - but if no one answers I would suggest you try it in the Ultimaker / Cura forums.
On which OS are you running cura?
I'm the creator of the Cura OctoPrint Connection plugin.
As you know, for diagnosing OctoPrint problems, we need to see octoprint.log. So it is somewhat logical that to diagnose Cura problems, we need to see cura.log. It can be found in the configuration folder in Cura, which can be accessed via Help -> Show configuration folder. Please upload the cura.log file somewhere (dropbox. google drive, etc) and post a link here.
It looks as if when you wanted to uninstall the plugin to reinstall it, you disabled it instead. Go to the "Installed" tab of the Marketplace, and make sure the checkmark in front of the OctoPrint Connection plugin is checked, not unchecked.
