Cura Plugin show 404 error on print
I got a 404 error - URL not found if I try to print with Cura directly to OctoPrint with the plugin. Sometimes it works and also every other feature is working fine like Webcam or requesting an API key. Only print is failing. Any ideas about it?
I still tried to disable auto-discovery and set URL by my own but without any change in the behavior.
Cheers,
Nils
A post was merged into an existing topic: Cura OctoPrint Connection plugin
