Started a print this morning and for the first 4 layers, OctoPrint reported the current height as 0.3mm. It was only when it got to layer 5 did it change to showing the correct height.
Refreshing the browser
browser.user_agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/111.0
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 914006016
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.8.4-20220927151125
env.plugins.pi_support.throttle_state: 0x80000
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2022-11-12T23:56:01Z
octoprint.last_safe_mode.reason: incomplete_startup
octoprint.safe_mode: False
octoprint.version: 1.8.6
printer.firmware: Marlin 2.0.6.0 (Jul 28 2021 10:39:52)
systeminfo.generated: 2023-02-26T08:19:21Z
systeminfo.generator: zipapi
OctoPrint 1.8.6. Creality Ender 2 Pro.
For all of these layers it was reporting the height as 0.3mm
octoprint.plugins.crealityprinter - INFO - tb_send_attributes:{'curPosition': 'X:84.36 Y:76.93 Z:0.2'}
octoprint.plugins.crealityprinter - INFO - tb_send_attributes:{'curPosition': 'X:78.69 Y:77.83 Z:0.4'}
octoprint.plugins.crealityprinter - INFO - tb_send_attributes:{'curPosition': 'X:78.69 Y:78.03 Z:0.6'}
octoprint.plugins.crealityprinter - INFO - tb_send_attributes:{'curPosition': 'X:78.69 Y:78.22 Z:0.8'}
Until this layer when it changed to correctly reporting the height.
octoprint.plugins.crealityprinter - INFO - tb_send_attributes:{'curPosition': 'X:78.69 Y:78.41 Z:1.0'}
