Current Versions
When I look at the current version under settings / Software Update, this is what it shows: 0+unknown.gd79a0d20 and there is no dropdown to allow me to pick what type of updates I want.
Restarted the server, booted into safe mode.
Yes
I'm supposed to be on RC 3 / 4, I can't remember which it is.
0+unknown.gd79a0d20 this indicates a manual install from a zip download URL from github, or possibly a git checkout (probably not). Best way to fix this would be to install from pip in the venv, but since you didn't include the system info bundle I'm not sure what that may be for you to provide the proper guidance.
octoprint-systeminfo-20250321102210.zip (19.7 KB)
Is this what you need?
yep, that helps. these commands over SSH should fix you up.
source ~/oprint/bin/activate
pip install --upgrade octoprint==1.10.3
deactivate
Thank you so much for your help. :smile:
After running these commands, when I load Octoprint via Browser, it tells me that 1.10.3 is ava. to install/upgrade. I allow it to do so and I am once again back to 0+unknown.gd79a0d20. Is this normal?
BTW: What is this plugin?
|  OctoPrint-E3V3SEPrintJobDetails (0.0.1.8) = /home/chaxe/oprint/lib/python3.9/site-packages/octoprint_E3V3SEPrintJobDetails
Also it seems you do not run on the standard /pi/ user
It's to enable printing to my Creality Ender 3 V3 SE printer, I sauppose I should uninstall / disable it as isn't working and when I ran the command line codes, at the end it give these errors:
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
octoprint-crealitycloud-with-video 1.1.1 requires aiortc, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires aliyun-python-sdk-vod==2.16.4, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires av, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires ffmpy, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires oss2, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires paho-mqtt, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires pyjwt, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires tb-mqtt-client==1.2, which is not installed.
octoprint-crealitycloud-with-video 1.1.1 requires voduploadsdk==1.0.2, which is not installed.
these errors appear to be from creality cloud plugin.
Yes, they are.
Did u see my prev reply?
need an updated system info bundle relative to that. I don't understand why it would do that unless one of those other plugins are doing something weird.
octoprint-systeminfo-20250322205727.zip (112.2 KB)
weird, definitely start by uninstalling creality cloud plugin and the other ender one if you don't need them. then share you software update settings for OctoPrint. What's picked in the drop down list and what shows under the gear icon for settings.
I uninstalled what plugins that I could and or seen. I do need the Creality heat as my Ender 3 V3 SE is the only machine I use Octo print on.
there we go. change github commit at the top of this to "relsease" like my screenshot.
Is that detail not in the SysInfoBundle? I am not familiar enough with them to know, but can't find it anywhere
I think it should be....
