The Control tab Tool buttons produce a feed rate that's too high for my extruder, even with the Flow Rate slider all the way down. Can the extruder rate controls be customized?
If you're going to adjust the extruder feedrate, you might want to spend some extra time calibrating it. It usually involves creating a pair of marks on white filament and then extruding 100mm or similar, comparing the extruded distance against reality. You'd then adjust the setting and repeat the testing until you got it to be more accurate than before.
I got fooled by the slider at first too. The trick is that, after you set the slider, you have to click the "Flow Rate" button below it to activate that setting. Then it works just like you'd expect. The fan control slider works the same way
Thanks for these ideas! After looking into them a bit*, let me try to ask a more specific question:
The Control > Tool > Extrude/Retract buttons generate commands like this (copied from Terminal):
Send: G91
Recv: ok P15 B4
Send: G1 E10 F300
Recv: ok P13 B4
Send: G90
Iβd like to reduce the feedrate value, currently F300. Manual testing shows that F50 is better. So, the desired output is:
G91
G1 E10 F50
G90
Is there a way to modify the output generated by these buttons, in particular the feedrate value?
*_Tried the Flow Rate slider (after pushing the accompanying button, thank you @Spyder ). It sends an M221 command, which changes the Extrude Factor. I think sending M221 S10 means that the extruder pushes through 10% of the material specified by the G1 command, but the feedrate looks the same to my eye.
You sure did!
I recalled setting up that field, but crucially not the footnote: "This information is used for manual control via the "Control" tab. It does NOT influence already sliced files that you upload to OctoPrint!"
Thank you.
I also had the same problem when I replaced my old extruder with another one.
The first part of the problem was, that my new extruder has a shorter "preheat" pipe than the previous one (the tube part between the heating head and the extruder cooler). Another problem was, that my new cooler is more efficient.
Under these circumstances my default extrusion speed was too high for my new "shorter" extruder. Problem was not during printing, but only when I moved manually with the Extrude button. The teeth on the extruder wheel were slipped because the filament could not heat up sufficiently in the shorter preheating element.
It was quite frustrating until I understood the need to reduce the E parameter in the profile setting, as BerndJM wrote. Also note that the Flow Rate button does not work during the manual extrusion.
