Octopi 0.18.0 RC1 on a Raspberry PI 4.
Ran desktop install script answered 'yes' at end to have it boot to desktop and rebooted. Now when it boots up I get a blank screen. Octopi/octoprint is running since I can log in via web browser from my other computer. But on the monitor i have plugged into the HDMI 0 (HDMI 1 doesnt output anything) just shows a blank screen with a single '_' at the top that doesn't even blink. There is no command line, no output on startup showing the pi boot messages, no nothin'. Just a blank screeen.
Like I said, octoprint is working so I'm not dead in the water, but I'd like to use the desktop.
Tried both HDMI ports, one doesn't output anything and the other outputs blank screen with underscore character at top. Unplugged/plugged in monitor. Switched monitor inputs. restarted the PI several times.
Not yet, just started a long print i don't want to interrupt. will do that when it is done.
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
Just started a long print. I'll add logs when it is done.
