I have a 'cooler' attached to the extruder, and i'm trying to connect to the port i pluged the cooler in via USB cable in order to send/receive data.
I developed an Octoprint plugin that is supposed to control the fan speed of the cooler and some other features, this is my plugin struture:
- assistant_plugin
-- /init.py
-- /templates/pluginGUI.jinja2
-- /static/js/gui_functions.js
I'm trying to implement the connection logic in the 'gui_functions.js' JavaScript file, i have done some research and what i found is, to connect to the port there are three main steps:
1- in my Raspberry Pi run "npm install serialport"
2- at the top of my javascript add "const { SerialPort } = require('serialport')"
3- then create a port "const port = new SerialPort({ path: '/dev/ttyUSB0', baudRate: 115200 });"
but all my tries are failing so far, it keeps showing this error in the console tab: "caught ReferenceError: require is not defined". I'm kinda new to this whole thing so my developing knowledge is little. any help is appreciated! ![]()
this is my JS code snippet for reference:
__
const { SerialPort } = require('serialport');
function PortConnectionViewModel(parameters) {
var self = this;
self.connect = function() {
const serialPort = new SerialPort({ path: '/dev/ttyUSB0', baudRate: 115200 });
serialPort.open(function(error) {
if (error) {
console.log(error);
return;
console.log("Connected to serial port");
serialPort.on('data', function(data) {
console.log('Received data:', data);
self.disconnect = function() {
if (serialPort) {
serialPort.close(function(error) {
if (error) {
console.error('Error closing port:', error.message);
} else {
console.log('Port is closed');
} else {
console.error('Serial port not open or not available');
__
yes
no since safe mode disables plugins.
What kind of hardware precisely, OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... as much data as possible
