On every login I get notified about a Plugin compatibility issue(specificly between UICustomizer+Themefiy and UICustomizer+Fullscreen). I assume this works as intendet and I get why this messages pop up, but so far I didnt ran into any issues so I decided to stay with my current setup. Therefore I want to disable the, by now, annoing notifications but I couldnt find any way of doing so(e.g. an option in the menu or a line in some config file).
Thanks in advance for any help.
Looked through the settings menus for an option to disable the notifications.
Cant say, but I highly doubt it.
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.81 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 1903304704
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 21.2.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
printer.firmware: Marlin 2.0.5.4 (knutwurst, Github)
It is my plugin making these notifications - they are dimissed pr. browser instance and saved in local storage.
They are mainly there because they plugins causes conflicts. I would recommend either removing my plugin or the others. They do the same and having overlapping functionality causes conflict.s
I suggest that you pick the one plugin which is closest to your "ideal" and then politely ask that plugin's author to add the feature from the other plugin that you can't live without.
If you continue to run both plugins you will have to live with the messages being generated. I'm pretty sure you won't get any sympathy from either plugin author about making the two plugins with highly overlapping functionality compatible.
Alternate plan B would be to fork both projects and undertake the merger yourself. This is the beauty of open source software.
They were asking for that but if I were the author of the plugin that was generating messages warning the user that they had an incompatible configuration, I would be a bit reluctant to spend effort to disable the warning. Sort of like:
Patient: "Doctor, it really hurts when I hit the wall with my fist, can you help me?"
Doctor: "I can certainly help, don't hit the wall with your fist."
I was suggesting an alternate solution to the problem. I guess I should have said " or fork the project and remove the messages".
