Hello everyone!
I'm trying to use klipper for controling stepper motors, but is doesn't connects. This is the error: No working connection parameters could be found. Are you sure your printer is physically connected and supported? Refer to the FAQ for help in debugging this. Can you tell me what should be problem?
I'm using raspi 4b, which is connecting to raspi pico H. TMC 2209 Tx pin is in raspi pico H Rx pin and TMC's Rx pin is in raspi pico's Tx pin. This is my printer.cfg file:
[tmc2209 stepper_x]
uart_pin: 11
run_current: 0.6
[tmc2209 stepper_y]
uart_pin: 16
run_current: 0.6
[mcu]
serial: /dev/ttyACM0
[printer]
kinematics: corexy
max_velocity: 300
max_accel: 500
[communication]
baud_rate: 115200
Can anyone help me?
