Hello, is it possible to disconnect and reconnect the serial connection via the console (terminal)? So the same process as the Disconnect and Connect buttons in the web interface.
Version 0.18.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Hello,
yes, you can do this with curl and the API
Specifically Connection handling
# connect octoPrint and the printer
curl -s -X POST -H "Content-Type: application/json" -H "X-Api-Key":"$OCTOPRINT_X_API_KEY" -d '{"command":"connect"}' http://$PRINT_HOST/api/connection
sleep .5
Replace $OCTOPRINT_X_API_KEY with an API key you generate in Settings and $PRINT_HOST with the hostname or IP to reach your box.
It works!! Thank you so much
