I just wondered if the disk usage seams correct on my pi 4. seams higher then what i have seen in other examples
pi@octopi:/ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 30G 2.1G 26G 8% /
devtmpfs 1.8G 0 1.8G 0% /dev
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 8.5M 1.9G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 53M 200M 21% /boot
tmpfs 386M 0 386M 0% /run/user/1000
I am new and not sure if there is anything or if this is perfectly normal. I worry about running into log space filling me up.
octoprint.log (205.2 KB)
pi 4B running OctoPi Version 0.17.0 and OctoPrint 1.4.0
