Yesterday I initialized three Raspberry Pi's with separate instances of Octoprint (unique URLs). Everything seemed to work fine until I started connecting my camera modules and now none of them seem to be working correctly (the stream in the Control tab is black, as if no camera is connected).
After doing some research it seems like cameras default to port 8080, and now I'm wondering that (even though I'm using three different Raspberry Pi's, with different URLs), could there be a clash if all cameras are defaulted to port 8080?
I'm quite new to this so sorry for the noob question, I just wanted to see if anyone had any advice on this before investigating if there are hardware issues. Especially as the cameras were all working fine when initializing the Octoprint instances, but now that they're all set up, there seems to be issues -
Yes
For all 3 printers:
OctoPi 1.0.0
OctoPrint 1.9.3 (camera stack build)
Prusa Mini
Firmware 5.1.2
rPi Camera Module
Accessing OctoPi via Google Chrome, and OctoPod iOs application.
Windows 10
Thanks for the reply - I'll have a look into the crash -
I've also just run a few recommended diagnostics that I found while browsing here - would these indicate a hardware issue or would these commands also show the same thing if the camera streamer crash was occurring?
jake@mini1:~ $ vcgencmd get_camera
supported=1 detected=0, libcamera interfaces=0
jake@mini1:~ $ libcamera-still -o test.jpg
Preview window unavailable
[0:05:16.332233204] [1131] INFO Camera camera_manager.cpp:297 libcamera v0.0.5+ 83-bde9b04f
ERROR: *** no cameras available ***
just found out in discord from someone else, that the detected=0 was because the camera wasn't loaded. check config.txt for the below line and make sure it's set to 1 and not commented.
