Raspberry Pi camera modul v1.3 (probably third party)
Cannot manually take pictures with command raspistill -v -o test.jpg. The error is quite common but i have not been able to fix it. Since this error can appear when 2 processes attempt to use the camera i wonder if OctoPi has a process that uses the camera automatically, so there would be 2 processes in total wanting to use it.
- raspi-config -> enable camera
- get all updates
- rpi update (fimware update)
- checked whether camera is correctly plugged in -> red light shines and raspbian detects the camera successfully
"raspistill" Camera App (commit bab9bf8790cd Tainted)
Camera Name ov5647
Using camera 0, sensor mode 0
GPS output Disabled
Quality 85, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 5000, Timelapse 0
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
latest (fresh installation)
camera is connected to camera port (csi), not usb
I just got my 3D printer recently and im currently trying to setup Octoprint for it.
