i have no connection between Dremel 3d40 and Canvas Hub S 1.4
i have Canvas Hub S and Canvas Hub, imy printer is a dremel 3d40.
normally i use simplify 4.0 with a usb connection.
but now the printer doesnt connect to the Canvas HUB, i rebootet all, i changed cables, ...... but no connection.
IF i connect to simplify it shows: USB Device: 10889/34955/00000000050C
after i shutdown the PC, i disconnect the usb i connect the usb to the Canvas HUB S, i reboot the printer, but no autodetect......
Octoprint 1.4,
Canvas HUB S,
serial (2).log (1.8 KB) octoprint (1).log (79.5 KB) Dremel 1.0_R03.05.05, the newest
