No serial port found, ssh does see dremel via usb cable, but does not assign tty for it
Checked SSH to see it is detected: Bus 001 Device 005: ID 2a89:888b BOSCH BOSCH Dremel 3D Printer
Tried directly to windows, works.
Added /dev/ttyAMA0 as manual port
Tried troubleshooting guide.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting https://github.com/Mrnt/OctoPrint-FlashForge/archive/master.zip
Downloading https://github.com/Mrnt/OctoPrint-FlashForge/archive/master.zip
\ 49 kB 610 kB/s
ERROR: Command errored out with exit status 255:
command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-3vrfya1c/setup.py'"'"'; __file__='"'"'/tmp/pip-req-build-3vrfya1c/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-7ll4vv57
cwd: /tmp/pip-req-build-3vrfya1c/
Complete output (1 lines):
Could not import OctoPrint's setuptools, are you sure you are running that under the same python installation that OctoPrint is installed under?
WARNING: Discarding https://github.com/Mrnt/OctoPrint-FlashForge/archive/master.zip. Command errored out with exit status 255: python setup.py egg_info Check the logs for full command output.
ERROR: Command errored out with exit status 255: python setup.py egg_info Check the logs for full command output.
