TESLONG Dual Lens USB - TESLONG 8.0mm Dual Lens USB Endoscope 5M Tube Inspection Camera for Android PC | eBay
I bought this as a relatively cost-effective auto-focus endoscope to use as a nozzle camera.
It works well, but the camera has a slightly strange design whereby there are two lenses - a normal one and a side one. The side one doesn't show anything useful as a result of where it's mounted, so I'd like to only show the main view:
I have it set up in /boot/octopi.txt for a 640x480 resolution, but mjpg_streamer overrides that and uses 1280x480 instead. I'd like to automatically crop the image so only the left-hand half is visible.
I read all the options in v4l2-ctl --help, v4l2-ctl -d /dev/video3 -l, /opt/mjpg_streamer --help and /opt/mjpg_streamer -i "input_uvc.so --help", but couldn't see anything that sounded promising.
config file='/boot/octopi.txt':USB device was set in options and found in devices, starting MJPG-streamer with the configured USB video device: /dev/video3
<13>Feb 18 10:48:29 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 24 -d /dev/video3
MJPG Streamer Version.: 2.0
i: Using V4L2 device.: /dev/video3
i: Frames Per Second.: 24
i: Format............: JPEG
i: The specified resolution is unavailable, using: width 1280 height 480 instead
i: FPS coerced ......: from 24 to 15
o: HTTP Listen Address..: 127.0.0.1
Running on Raspberry Pi 4, OS version info:
/etc/os-release:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
SystemInfo bundle:
octoprint-systeminfo-20220218120924.zip (33.0 KB)
