Hi, I have A HEVO with Duet WiFi, I like it but I would like to control it from an app on my phone, so I set up OctoPrint but then I ran into a lot of problems, the first: OctoPrint does not recognize the SD card in the duet and does not show the gcode files; second: OctoPrint does not realize the printer is printing if the print was started from the DWC or display.
I need to use the builtin SD card because if I want to get the full performance, the USB is not fast enough. These things make OctoPrint useless for me and that is a shame
Did you ever find a solution to octoprint not seeing the print start from the duet?
Any updates? I already have octoprint but I want to install and use duet 2 wifi
Still no updates? I would use octoprint with the duet as well.
