Hi there!
I was wondering if anybody knew whether it was possible to use Octoprint on the Easythreed X1? The printer can be used over USB or Micro SD and doesn't have a display.
Many thanks,
Dominic.
Hello @Dominic_McGreevy!
You could try with Pronterface first. When you can print from there, there is a huge chance it will work with OctoPrint too.
Hi, I tried to connect to my Easythreed x1 from octoprint and it appears to work. Did not try to print but I can move and set temperature so it should work
Thanks for your help! I'll try it out and let you know if it works.
