Eric_L
December 10, 2020, 8:43pm
1
Camera model raspberry pi 1.3
What is the problem? Settings
Logs (/var/log/webcamd.log, syslog, dmesg, ... no logs, no support )
Is there anyway to get the ability to change settings in octoprint for the raspberry pi camera?
Looks like there are controls for brightness, contest ect.
You can do this with a plugin like
or in the
octopi.txt on your sd cards boot partition
The following configuration options can be supplied to MJPG Streamer on start to modify certain camera settings. To change any of these options in OctoPi, edit the relevant sections in octopi.txt as described here .
USB webcams (input_uvc.so)
input_uvc.so comes bundled with MJPG Streamer.
-d <device>: The video device to use, e.g. -d /dev/video0
-r <resolution>: The resolution, e.g. -r 640x480 for 640x480px
-f <framerate>: The framerate in frames per second, e.g. -f 10 for 10 fps
-q <qualβ¦
Eric_L
December 10, 2020, 8:58pm
3
Looks like octolapse has the camera control settings I need. Not sure why this isn't stock in the webcam tab in octoprint
You're free to post a pull request on github anytime
foosel
December 10, 2020, 9:05pm
5
Nope, not in this case. It isn't in core because OctoPrint isn't OctoPi and not everyone runs OctoPi and/or uses the bundled webcam server that can be configured through that file.
This is what plugins are for.
Eric_L
December 10, 2020, 9:19pm
6
I honestly didn't realize OctoPrint was for other platforms other than the Raspberry Pi because the vast majority of the Download page is dedicated to OctoPi. It wasn't until I scrolled down further that I realized it isn't just a raspberrypi software.
yup
I use it on an x86 machine myself
