Edit the firstboot file
good day I am setting up my Makergear Ultra 1 I put in a new Resparry pi 4 made the sd card and now i am editing the firstboot file there is the file name firstboot.sh.done should i remove the (.done )or leave it that way the instructions only has the (.sh) or does it realy matter
Hello @GeoffreyIra !
In this document OctoPrint.org - Download & Setup OctoPrint there is no firstboot.shfile mentioned and I've never heard of it in context with OctoPrint and/or OctoPi.
BTW: Your text is a bit hard to read.
