I am getting this Error after the last OctoPi update
Error reported by printer
Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: EEPROM CRC mismatch - (stored) 33767 != 49747 (calculated)!
disable
Enable automatic firmware detection
Raspbarry Pi 3 B+
OctoPrint version 1.42
OctoPi version 0.17.0
printer Ender 5 Plus
firmware ver 1.70.2 BL
browser Window Edge
operating system Windows 10
If your printer has an LCD screen look for a reset to factory defaults. That's the best advice I can give you since you ignored:
Just to make this absolutely clear: this error comes from your printer, OctoPrint only displays it to you, it is not the cause of it.
What you could do however is tell OctoPrint to not disconnect on it (somewhere in Settings > Serial Connection > Behaviour if I remember correctly) and see if that allows you to proceed with connecting (and maybe resetting that way).
