Elegoo Neptune 4 Pro won't connect
I want to connect my Elegoo Neptune 4 Pro to OctoApp.
It keeps saying "testing connection to your printer" and doesn't continue.
I also installed octoerverywhere plugin on my printer and connected the printer to Octoeverywhere. When I generate a http-url through octoeverywhere and enter it in OctoApp the same message appears and doesn't go away.
No.
Don't know
I already managed to get OctoPrint running on my Elegoo Neptune 3 PRO with a raspberry Pi.
Hello @etalon !
Please do so.
Where is this section gone?
Please attach the systeminfo bundle to your next post.
@Ewald_Ikemann Did you read my post? I have not installed OctoPrint on my Elegoo. I only have klipper. If I am correct OctoApp is able to connect directly to klipper. I only installed OctoEverywhere onto the printer. So I can't give you a systeminfo bundle if im right. My printer runs klipper/moonraker/fluidd.
The word Klipper is not mentioned in your first post.
Then this is the wrong forum.
You should go:
I managed to solve my problem. Here is how:
The previous owner of the printer seemed to modified the printer. So I reinstalled the firmware and the old files with the help of this great tutorial: https://www.youtube.com/watch?v=8Bdd126WHOI&ab_channel=LuBiTechChannel
After this the connection worked properly. For additional features I installed OctoApp for Klipper via Kiauh
Hope this can help someone...
