Elegoo Satrun2 cannot start print from ctb files in the SD card in the octrprint server
The Elegoo Saturn2 printer cannot start to print any uploaded files on the 64 GB SD card when it is operational after connected to Octoprint server. Here is how it looks on the terminal, please have look to logs section.
I installed OctoPi version: 0.18.0 with OctoPrint version: 1.8.6 by using the Raspberry Pi 4B connected through /dev/ttyS0 baudrate: 115200. The octopi is installed with octoprint plugins chituboard.
The priner is connected by the jumper wires from the Raspberry Pi’s GPIO pins to the Elegoo Saturn2 motherboard. The TX pin is connected to the motherboard’s RX pin, GND to GND, Rx to Tx.
the Pi USB connector is connected to the “USB Disk” USB port on the printer’s motherboard with the USB Power Blocker to strip 5V from a USB cable.
Used the following command.
wget https://raw.githubusercontent.com/rudetrooper/Octoprint-Chituboard/main/Chituboard.sh
sudo chmod +x ./Chituboard.sh
sudo bash ./Chituboard.sh
in safe mode it didn't work too.
Logs
octoprint.log on terminal tab
Send: N0 M110 N0125
Recv: //
Recv: \x00#checkSum error,i:2 expect:0x7e,actual:0x7d!str:N0
125
WARNThe received line contains at least one null byte character at position 0, this hints at some data corruption going on
Recv:
Recv: ok
Send: M115
Recv: ok CBD make it.Date:Jan 10 2022 Time:16:04:13
Repl: ok CBD make it.Date:Jan 10 2022 Time:16:04:13
-> ok FIRMWARE_NAME:CBD made it PROTOCOL_VERSION:V4.5.0_1.1_EL03_LCDE1
Send: M21
Recv: //DN:2
Recv: \x00it fail!
Recv: ok N:2
Send: M20
Recv: Begisk init fail!//Disk init fail!
Recv: /nd file list
Recv: \x00!
Recv: Eait
Recv: \x00e list
Recv: wk L:0ok L:0
Recv: ok
Send: M4000
Recv: ok B:0/0 X:0.000 Y:0.000 Z:-0.300 F:256/256 D:0/0/1 ok
Repl: ok T:0 /0 B:0 /0
Thanks in advance!
Hello @LifeiFu !
That is just the terminal output, not the octoprint.log.
Please share the systeminfo bundle in your next post.
Also try this plugin:
Thanks for your reply, I just installed Fix CBD Firmware Plugin (0.4.0).
sorry, I didn't put the right octoprint.log in the post.
here is the log file messages:
2022-12-16 20:49:45,248 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2022-12-16 20:49:45,248 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2022-12-16 20:49:45,249 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-manifest.json...
2022-12-16 20:49:45,332 - octoprint.plugins.bedlevelvisualizer - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2022-12-16 20:49:45,332 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin bedlevelvisualizer is DISABLED
2022-12-16 20:49:45,336 - octoprint.plugins.octolapse - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2022-12-16 20:49:45,336 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin octolapse is DISABLED
2022-12-16 20:49:45,735 - octoprint.server - INFO - Shutting down intermediary server...
2022-12-16 20:49:46,108 - octoprint.server - INFO - Intermediary server shut down
2022-12-16 20:49:46,110 - octoprint.events - INFO - Processing startup event, this is our first event
2022-12-16 20:49:46,111 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2022-12-16 20:49:46,111 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2022-12-16 20:49:46,120 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2022-12-16 20:49:46,127 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2022-12-16 20:49:46,161 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-12-16 20:49:46,389 - octoprint.filemanager.analysis - INFO - Starting analysis of local:little_goku_6h.ctb
2022-12-16 20:49:46,505 - octoprint.server - INFO - Trying to connect to configured serial port /dev/ttyS0
2022-12-16 20:49:46,550 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': True, 'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2022-12-16 20:49:46,904 - octoprint.filemanager - INFO - Added 4 items from storage type "local" to analysis queue
2022-12-16 20:49:47,212 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2022-12-16 20:49:47,214 - octoprint.util.comm - INFO - Connecting to port /dev/ttyS0, baudrate 115200
2022-12-16 20:49:47,264 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2022-12-16 20:49:47,291 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2022-12-16 20:49:47,303 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2022-12-16 20:49:47,414 - octoprint.plugins.chituboard - INFO - Replacing ok V4.5.0_1.1_EL03_LCDE1
with ok start
2022-12-16 20:49:47,414 - octoprint.plugins.chituboard - INFO - Further replacements of this kind will be logged at DEBUG level.
2022-12-16 20:49:47,740 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2022-12-16 20:49:47,939 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-12-16 20:49:48,005 - octoprint.util.comm - WARNING - Received line:
2022-12-16 20:49:48,006 - octoprint.util.comm - WARNING - | \x00#checkSum error,i:2 expect:0x7e,actual:0x7d!str:N0*125
2022-12-16 20:49:48,006 - octoprint.util.comm - WARNING - The received line contains at least one null byte character at position 0, this hints at some data corruption going on
2022-12-16 20:49:48,083 - octoprint.plugins.chituboard - INFO - Replacing ok CBD make it.Date:Jan 10 2022 Time:16:04:13
with ok FIRMWARE_NAME:CBD made it PROTOCOL_VERSION:V4.5.0_1.1_EL03_LCDE1
2022-12-16 20:49:48,085 - octoprint.util.comm - INFO - Printer reports firmware name "CBD made it"
2022-12-16 20:49:48,115 - octoprint.util.comm - WARNING - Received line:
2022-12-16 20:49:48,252 - octoprint.util.comm - WARNING - | \x00it fail!
2022-12-16 20:49:48,252 - octoprint.util.comm - WARNING - The received line contains at least one null byte character at position 0, this hints at some data corruption going on
2022-12-16 20:49:48,450 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {'firmware_name': 'CBD made it', 'printer_port': '/dev/ttyS0', 'printer_baudrate': 115200}
2022-12-16 20:49:48,578 - octoprint.util.comm - WARNING - Received line:
2022-12-16 20:49:48,578 - octoprint.util.comm - WARNING - | \x00!
2022-12-16 20:49:48,579 - octoprint.util.comm - WARNING - The received line contains at least one null byte character at position 0, this hints at some data corruption going on
2022-12-16 20:49:48,599 - octoprint.util.comm - WARNING - Received line:
2022-12-16 20:49:48,640 - octoprint.util.comm - WARNING - | \x00e list
2022-12-16 20:49:48,679 - octoprint.util.comm - WARNING - The received line contains at least one null byte character at position 0, this hints at some data corruption going on
2022-12-16 20:49:49,740 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-12-16 20:49:50,740 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Ziegler Lab"._http._tcp.local.' for _http._tcp.local.
2022-12-16 20:49:51,235 - octoprint.filemanager.analysis - INFO - Analysis of entry local:little_goku_6h.ctb finished, needed 4.85s
2022-12-16 20:49:51,566 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Ziegler Lab"._octoprint._tcp.local.' for _octoprint._tcp.local.
2022-12-16 20:49:51,585 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "Ziegler Lab" for SSDP
2022-12-16 20:49:51,609 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2022-12-16 20:49:51,677 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-12-16 20:49:51,859 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:132.199.73.186
2022-12-16 20:49:52,230 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:132.199.73.186
2022-12-16 20:49:52,247 - octoprint.filemanager.analysis - INFO - Starting analysis of local:4W5T_ribbons_Hbonds.ctb
2022-12-16 20:49:52,277 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2022-12-16 20:49:52,302 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-12-16 20:49:52,302 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-12-16 20:49:52,324 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 48.2GB. That is considered sufficient for updating.
2022-12-16 20:49:53,698 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2022-12-16 20:49:53,698 - octoprint.plugins.chituboard - INFO - Octoprint-Chituboard plugin startup
2022-12-16 20:49:53,891 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 10, 'printer_state': 'OPERATIONAL'}
2022-12-16 20:49:54,227 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.8.6', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1500.0, 'ram': 3971166208, 'pi_model': 'Raspberry Pi 4 Model B Rev 1.2', 'octopi_version': '0.18.0', 'octopiuptodate_build': '0.18.0-1.8.6-20221018093204', 'plugins': 'printtimegenius:2.3.0,chituboard:0.1.4,octolapse:0.4.1,bedlevelvisualizer:1.1.1,abl_expert:0.6'}
2022-12-16 20:49:54,522 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'version': '1.8.6', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1500.0, 'ram': 3971166208, 'pi_model': 'Raspberry Pi 4 Model B Rev 1.2', 'octopi_version': '0.18.0', 'octopiuptodate_build': '0.18.0-1.8.6-20221018093204'}
2022-12-16 20:49:54,638 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://132.199.74.255/', 'path': '/', 'query_string': 'l10n=en'}
2022-12-16 20:49:55,246 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-12-16 20:49:57,116 - octoprint.filemanager.analysis - INFO - Analysis of entry local:4W5T_ribbons_Hbonds.ctb finished, needed 4.87s
2022-12-16 20:49:58,103 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:132.199.73.186
2022-12-16 20:49:58,148 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Totoro2.ctb
2022-12-16 20:50:00,618 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:132.199.73.186
2022-12-16 20:50:03,015 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Totoro2.ctb finished, needed 4.87s
2022-12-16 20:50:04,016 - octoprint.filemanager.analysis - INFO - Starting analysis of local:little_goku.ctb
2022-12-16 20:50:08,771 - octoprint.filemanager.analysis - INFO - Analysis of entry local:little_goku.ctb finished, needed 4.75s
2022-12-16 20:50:08,892 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/logitech_c920.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/logitech_c920.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2022-12-16 20:50:08,903 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/raspi_cam_v2.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/raspi_cam_v2.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2022-12-16 20:50:08,918 - octoprint.util.jinja - WARNING - Loading plugin template '/webcams/mjpg_streamer/logitech_c250.jinja2' from '/home/pi/oprint/lib/python3.7/site-packages/octoprint_octolapse/templates/webcams/mjpg_streamer/logitech_c250.jinja2' without plugin prefix, this is deprecated and will soon no longer be supported.
2022-12-16 20:50:11,713 - octoprint.server.preemptive_cache - INFO - ... done in 17.07s
2022-12-16 20:50:49,731 - octoprint.access.users - INFO - Logged in user: saturn2
2022-12-16 20:50:49,733 - octoprint.server.api - INFO - Actively logging in user saturn2 from ::ffff:132.199.73.186
2022-12-16 20:50:49,801 - octoprint.server.util.flask - INFO - Passively logging in user saturn2 from ::ffff:132.199.73.186
2022-12-16 20:50:49,801 - octoprint.access.users - INFO - Logged in user: saturn2
2022-12-16 20:50:50,083 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:132.199.73.186
2022-12-16 20:50:50,853 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:132.199.73.186
2022-12-16 20:50:50,882 - octoprint.server.util.flask - INFO - Passively logging in user saturn2 from ::ffff:132.199.73.186
2022-12-16 20:50:50,882 - octoprint.access.users - INFO - Logged in user: saturn2
2022-12-16 20:50:52,067 - octoprint.server.util.sockjs - INFO - User saturn2 logged in on the socket from client ::ffff:132.199.73.186
2022-12-16 20:50:52,716 - octoprint.plugins.tracking - INFO - Sent tracking event webui_load, payload: {'browser_name': 'Chrome', 'browser_version': '108.0.0.0', 'os_name': 'Windows', 'os_version': '10'}
2022-12-16 20:50:56,251 - octoprint - ERROR - Exception on /api/files/local/4W5T_ribbons_Hbonds.ctb [POST]
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_chituboard/sla_printer.py", line 126, in select_file
sliced_model_file = file_format.read_dict(Path(path_on_disk),fileData["analysis"])
KeyError: 'analysis'
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 2073, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 1519, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 1517, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/lib/python3.7/site-packages/flask/app.py", line 1503, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/util/flask.py", line 1598, in decorated_view
return func(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/api/files.py", line 874, in gcodeFileCommand
printer.select_file(filenameToSelect, sd, printAfterLoading, user)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_chituboard/sla_printer.py", line 130, in select_file
sliced_model_file = file_format.read(Path(path_on_disk))
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_chituboard/file_formats/ctb.py", line 206, in read
ctb_param = CTBParam.unpack(file.read(CTBParam.get_size()))
File "/home/pi/oprint/lib/python3.7/site-packages/typedstruct.py", line 89, in unpack
return cls(*unpack(cls.get_format(), buffer))
struct.error: unpack requires a buffer of 60 bytes
2022-12-16 20:50:58,277 - octoprint - ERROR - Exception on /api/files/local/4W5T_ribbons_Hbonds.ctb [POST]
2022-12-16 20:50:58,429 - octoprint - ERROR - Exception on /api/files/local/4W5T_ribbons_Hbonds.ctb [POST]
I asked for the systeminfo bundle.
However, please format the log with :
Format
It's really hard to read it this way. Also, special characters and formating get lost.
the cbd firmware won't help in this situation I don't think since this is a resin printer and not fdm. the error listed in the octoprint.log is specific to the chithuboard plugin. the error appears to be specific to file analysis results possibly. You might want to check thru that plugin's GitHub repository issue tracker for potential similar error messages.
this looks like a possible similar issue.
Thanks, from the info, the chithuboard plugin didn't work.
chituboard
octoprint-systeminfo-20221217164517.zip (28.4 KB)
It seems you have a problem with the PSU:
2022-12-17 16:42:39,722 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
|      throttle_state: '0x50000'
More information on this:
