After 10 hours of printing a large model, OctoPrint failed with USB "SerialException" error.
dmesg in Pi says:
[Mon Jan 2 17:11:12 2023] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[Mon Jan 2 17:11:12 2023] usb 1-1.4: USB disconnect, device number 3
[Mon Jan 2 17:11:12 2023] usb 1-1.4: failed to send control message: -19
[Mon Jan 2 17:11:12 2023] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[Mon Jan 2 17:11:12 2023] ch341 1-1.4:1.0: device disconnected
[Mon Jan 2 17:11:13 2023] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[Mon Jan 2 17:11:13 2023] usb 1-1.4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[Mon Jan 2 17:11:13 2023] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[Mon Jan 2 17:11:13 2023] usb 1-1.4: Product: USB Serial
[Mon Jan 2 17:11:13 2023] ch341 1-1.4:1.0: ch341-uart converter detected
[Mon Jan 2 17:11:13 2023] usb 1-1.4: ch341-uart converter now attached to ttyUSB0
New Ender 2 pro, 4.2.3 board, Marlin 2.0.6.1, Pi 4B with 4 GB RAM and original power supply, "not cheap" 0.9 meter USB cable (5V Pin not masked) plugged into Pi USB 2.0 connector. 115200 baud set.
I am going to order another USB cable, but did not find one (which looks to be "pro") with ferrite, yet.
No. I have only a few plugins installed and it looks like a failure on the hardware level.
octoprint-systeminfo-20230102214530.zip (242.5 KB)
Pi 4B, OctoPi 0.18.0, OctoPrint 1.8.6.
Any hints?
Is 5V Pin masking needed for this printer? The printer display does not light up when the Pi is connected and the printer is off.
Thanks!
