Printing stops every time due to communication error
Changing USB cables, upload files to SD card
No, I thought I could not cause of Creality-2x-temperature-reporting-fix plugin
Can't tell
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 914006016
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.8.1-20220524101555
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.8.1
systeminfo.generated: 2022-06-05T13:16:24Z
systeminfo.generator: zipapi
OctoPrint 1.8.1
Raspberry Pi 3 Model B+
Creality Ender 3
I also had to install Creality-2x-temperature-reporting-fix plugin.
Normal printing without OctoPrint works fine with the same gcode.
My only successfull prints with OctoPrint were simple 15 minute prints.
More complex prints like motherboard fan cover always stop after cca 40 minutes.
last error terminal: Recv: okSend: N8660 G1 X116.805 Y123.894 E638.87753*87Recv: okSend: N8661 - Pastebin.com
Does anyone know how to fix this please? Thanks.
