Printer Disconnecting from OctoPrint (or computer?)
I have run several different cables with ferite magnets or not. Tried with different OS. Different USBC hubs nothing seems to prevent the printer disconnecting.
Yes
Bundle here vv
octoprint-systeminfo-20221229192945.zip (151.5 KB)
OctoPrint version: 1.8.6, 2016 Macbook Pro running Ubuntu 22.04 is the OctoPrint host, Creality Ender 3 running Marlin 2.1.2 slightly modified for CR touch and temp/ position/ sd print auto reporting, Browsers: Chrome, Edge, Brave, Client OS: Windows 11
Very simmilar to Getting urb stopped: -32 error for months, out of ideas on what to try - #13 by Nelson524 but this didn't seem to help me.
This has been a problem for a month ever since I attempted to set up octoprint on this Macbook. I originally tried using MacOS to run it but it started disconnecting and having serial usb problems. I installed Ubuntu on it and seemed to have better luck at first (after removing brltty). Then it started having the same issues. I've used 4 different USBC hubs with the machine including a powered dock. I'm not using octoprint to fully host prints because of this so I have only run SD Card prints. Atleast then I don't loose hours / days of progress. I think the issue might be on the Linux side but it might be a bit out of my league. I watch dmesg | grep USB and find as soon as I get
ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
OctoPrint starts throwing communication timeouts. I did also try taping the 5v pin and not taping the 5v pin on the various usb cables I used. Here is a copy of a full report from dmesg | grep USB just incase:
[ 0.213385] ACPI: bus type USB registered
[ 0.276625] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.276648] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.276669] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.996327] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.001965] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.001970] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.002102] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.002106] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.003857] hub 1-0:1.0: USB hub found
[ 1.005815] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.005818] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.007212] hub 2-0:1.0: USB hub found
[ 1.007783] xhci_hcd 0000:07:00.0: new USB bus registered, assigned bus number 3
[ 1.010120] xhci_hcd 0000:07:00.0: new USB bus registered, assigned bus number 4
[ 1.010124] xhci_hcd 0000:07:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.010154] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.010157] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.010255] hub 3-0:1.0: USB hub found
[ 1.010398] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.010400] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.011325] hub 4-0:1.0: USB hub found
[ 277.709307] usb 1-8: new high-speed USB device number 2 using xhci_hcd
[ 277.862260] usb 1-8: New USB device found, idVendor=0bda, idProduct=5487, bcdDevice= 1.47
[ 277.862265] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 277.863239] hub 1-8:1.0: USB hub found
[ 278.153418] usb 1-8.5: new high-speed USB device number 3 using xhci_hcd
[ 278.257127] usb 1-8.5: New USB device found, idVendor=413c, idProduct=b06e, bcdDevice= 1.01
[ 278.257148] usb 1-8.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 278.279954] usbhid: USB HID core driver
[ 278.427505] hid-generic 0003:413C:B06E.0001: hiddev0,hidraw0: USB HID v1.11 Device [Dell dock] on usb-0000:00:14.0-8.5/input0
[ 278.573547] usb 1-8.3: new high-speed USB device number 4 using xhci_hcd
[ 278.689515] usb 1-8.3: New USB device found, idVendor=0bda, idProduct=5413, bcdDevice= 1.21
[ 278.689520] usb 1-8.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 278.690961] hub 1-8.3:1.0: USB hub found
[ 278.981529] usb 1-8.3.3: new full-speed USB device number 5 using xhci_hcd
[ 279.084241] usb 1-8.3.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 279.084246] usb 1-8.3.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 279.084248] usb 1-8.3.3: Product: USB Serial
[ 279.173733] usb 1-8.3.5: new high-speed USB device number 6 using xhci_hcd
[ 279.285130] usb 1-8.3.5: New USB device found, idVendor=413c, idProduct=b06f, bcdDevice= 1.01
[ 279.285135] usb 1-8.3.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 279.291808] hid-generic 0003:413C:B06F.0002: hiddev1,hidraw1: USB HID v1.11 Device [Dell dock] on usb-0000:00:14.0-8.3.5/input0
[ 279.305084] usbserial: USB Serial support registered for generic
[ 279.307995] usbserial: USB Serial support registered for ch341-uart
[ 279.314860] usb 1-8.3.3: ch341-uart converter now attached to ttyUSB0
[ 279.376276] hid-generic 0003:413C:B06F.0003: hiddev1,hidraw1: USB HID v1.11 Device [Dell dock] on usb-0000:00:14.0-8.3.5/input0
[ 280.622105] usb 1-8.3.2: new high-speed USB device number 7 using xhci_hcd
[ 280.723732] usb 1-8.3.2: New USB device found, idVendor=1b3f, idProduct=2247, bcdDevice= 1.00
[ 280.723735] usb 1-8.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1471.057094] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 8341.570495] ch341-uart ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
Any help you guys have would be absolutely appreciated.
