The problem I am having is a 112 shut down for some reason and can not figure out why. I thought it was a thermal shut down of the hit end, replaced the entire unit with a new one and did the same thing on the next print. Removed the board 4.2.7 and checked all screws and connections and printed two prints and failed again. Sometimes its 2-3rd layer sometimes it 24hr in. Sometimes it works fine.
I have the logs from the last print where it failed and was wondering if someone can look at them and tell if its physical failure or software etc. octoprint.log (400.4 KB)
Replaced hot end, checked connections, done all the physical stuff I can do to the printer.
| Recv: Error:Thermal Malfunction, system stopped! Heater_ID: E0
2022-10-17 11:47:46,592 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Error"
2022-10-17 11:47:46,607 - octoprint.util.comm - INFO - Force-sending M112 to the printer
Check your printer for proper heating (extruder and bed) and thermo sensors. Check for loose contacts and/or plugs.
Also please avoid to power cycle the Pi. Sooner or later it will lead a corrupted file system on the Pi's SD card.
Thanks for the response. E0 which heater is that. IS that the bed, I thought E1 is hot end. Funny thing is it used to say Thermal runaway Heater E1 etc. now it just shows 112 shut down that's why I could not figure out what was the cause and was thinking it was something else because it usually reports the thermal event
I did not realize on the Pi. I have them shut down when the printer is off, they are powered off the printer. I may reload the card and rewire to keep them on.
Keith
ok I will disassemble it and check each pin and wire again. I see that too now that I found the error lines and reading more and more of the code. Thanks for the help
so I took the covers off the hot end and the main board and check all connections tightened up the pins and made sure the screws and everything was tight and good. Started another print and same thing it shut down 5 min into it. that was in safe mode with octoprint so that kind of rules out plug in issues with the software in my book. I am leaning toward firmware and or board. Going to refresh and see what it does.
