OctoPrint doesn't detect the printer
I am a new user and I have OctoPrint running on my windows pc. I know it isn't conventional, but I already have my pc running 24/7 so I didn't think it made sense for me to buy a Pi for this situation. OctoPrint is running fine, I have my webcam hooked up and I even enabled the Virtual printer to troubleshoot and confirm that it was all setup correctly. The only solution I've been able to find for this issue is "try another USB cable", I've tried at least 5, and I know the cables all worked because I can hear the device connected sound on my pc whenever I plug the printer in. I've updated the OS, as well as updated OctoPrint through the web interface. I have no idea what the solution is.
Performing autodetection with 7 port/baudrate candidates: COM3@115200, COM3@250000, COM3@230400, COM3@57600, COM3@38400, COM3@19200, COM3@9600
Trying port COM3, baudrate 115200
Connecting to port COM3, baudrate 115200
Unexpected error while connecting to serial port COM3, baudrate 115200 from hook default: SerialException: 'could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)' @ comm.py:_open_serial:3775
Could not open port COM3, baudrate 115200, skipping
Trying port COM3, baudrate 250000
Connecting to port COM3, baudrate 250000
Unexpected error while connecting to serial port COM3, baudrate 250000 from hook default: SerialException: 'could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)' @ comm.py:_open_serial:3775
Could not open port COM3, baudrate 250000, skipping
Trying port COM3, baudrate 230400
Connecting to port COM3, baudrate 230400
Unexpected error while connecting to serial port COM3, baudrate 230400 from hook default: SerialException: 'could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)' @ comm.py:_open_serial:3775
Could not open port COM3, baudrate 230400, skipping
Trying port COM3, baudrate 57600
Connecting to port COM3, baudrate 57600
Unexpected error while connecting to serial port COM3, baudrate 57600 from hook default: SerialException: 'could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)' @ comm.py:_open_serial:3775
Could not open port COM3, baudrate 57600, skipping
Trying port COM3, baudrate 38400
Connecting to port COM3, baudrate 38400
Unexpected error while connecting to serial port COM3, baudrate 38400 from hook default: SerialException: 'could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)' @ comm.py:_open_serial:3775
Could not open port COM3, baudrate 38400, skipping
Trying port COM3, baudrate 19200
Connecting to port COM3, baudrate 19200
Unexpected error while connecting to serial port COM3, baudrate 19200 from hook default: SerialException: 'could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)' @ comm.py:_open_serial:3775
Could not open port COM3, baudrate 19200, skipping
Trying port COM3, baudrate 9600
Connecting to port COM3, baudrate 9600
Unexpected error while connecting to serial port COM3, baudrate 9600 from hook default: SerialException: 'could not open port 'COM3': PermissionError(13, 'Access is denied.', None, 5)' @ comm.py:_open_serial:3775
Could not open port COM3, baudrate 9600, skipping
Changing monitoring state from "Detecting serial connection" to "Error"
OctoPrint version: 1.7.0
pip version: 21.3
Printer: Creality Ender 3 MAX w/ CR touch (same as BL touch)
Firmware: Marlin Ver 1.0.1.6
OS: Windows 10
