Not a problem as such, more of a question. I have an Ender 3 max with a 4.2.7 main board and would like to know if the printer needs the power & ground wires connected for the USB to work. If not I'll splice a micro USB into a 5 amp USB-C cable to charge the phone & print simultaneously. Then the printer won't complain when the power is off & the USB is still connected. My printer disconnects randomly but reliably when using Octoprint on a Pi4, I came across Octo4a yesterday & installed it on an old phone this morning. I had a print going which started normally but after about 3 hours the camera stopped. I didn't worry about it, the printer was still going strong. A couple of hours later the print stopped, I was ready to jump on the printer but instead I came on this forum & saw that someone had good results wrapping the board in tin foil. While doing that I had to move the phone & that's when I found the battery was dead flat, the phone had died & killed Octoprint.
I have ferrite beads on all the cables, stepper motor cables too.
I have wrapped the motherboard in tin foil but not tested yet
Unknown
I didn't do this because I hope someone can say yes or no to the question
What kind of hardware precisely, OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... as much data as possible
