On my Ender 3 when Ocoprint connects it has X and Y move to 115, it just moves with out doing a home so depending on where I left X and Y it will crash at the max and grind across the belt. I have no g-code defined on start up but something on connection is issues a move of 115.
It hasn't always done this and i have tried to disable plugins but not sure what is going on here. Would be thankful for any ideas.
Your serial log and octoprint log don't span the same period. The phantom move you report happens after the end of the output in your octoprint log. Just looking at the serial log, it looks like the move is enqueued amidst things happening because of the ABL Expert Plugin, so that would we a likely culprit.
Thanks, I forgot to pull a new log when I enabled the serial log. I thought i disabled the ABL, but I will try to disable it again after my current print finishes thanks!
