I am new to Octoprint, and 3D printing in general. That being said, I quickly realized the stock Creality firmware is crap (and didn't fully support Octoprint) and am now running TH3D's Marlin 2.0 firmware. I finished setting everything up (Including copying the starting/ending gcode directly from Creality's slicer into Octoprint) and went to start my first print. To my dismay, the printer did not preheat the bed or nozzle, and immediately started printing. Obviously, this probably isn't going to work. I have a feeling I missed something important in the setup, but I'm apparently being dense and can't find any help through Google.
Verified the start/end GCode is the same as what the slicers user. Tried re-slicing my model and restarting a print.
I think this is the problem. You don't need to duplicate the gcode from the slicer into OctoPrint, otherwise it is applied twice. If this gcode has placeholders in it for the temperatures (often configured in the slicer settings), these will be invalid in OctoPrint and so the temperatures may not be set. In the serial log, it is showing sending the start gcode, but yeah there's no heating commands before the extrusion attempts.
What is the contents of the start gcode in both OctoPrint & the slicer?
Ahh, interesting. Here's the gcode I pulled from the slicer software:
Start:
G28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
End:
G91 ;Relative positionning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positionning
G1 X0 Y0 ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
