Unfortunately I'm getting random SerialException issues with my Ender 3 (4.2.2 board) which strike very often.
I'm starting to run out of ideas, and beginning to come around to the idea of going back to using the SD card
I've put down any info I can think of, but please do let me know if there's anything missing.
- Tried a couple of USB cables, I'm about to try a 3rd (or 4th - losing track!). If there's any recommendations for known good USB cables available in the UK, please let me know!
- Attached some of these ferrite cores to both Pi power and printer USB cables
- Tried a Pi 3 and a Pi 4
- Used different power adapters for the Raspberry Pi's, I'm not getting any throttle or power warnings
- Moved the Pi/s outside of the enclosure, but still with short USB cables going to printer
- Turned off LED lights inside enclosure in case of interferance
- Moved LCD cables as per this suggestion
- Taped over USB power pin
- Turned off LED strip inside enclosure, on the off chance it might help reduce interference
Yes
Here
- OctoPrint version: Version 1.6.1
- OctoPi Version 0.17.0, running on Raspberry Pi 3 Model B Rev 1.2
- Printer Ender 3 (with 4.2.2 board)
- Using a BLTouch for bed leveling
- No extra USB peripherals are attached to the Raspberry Pi, but there is one of the raspberry pi ribbon cameras attached
- Firmware: Marlin 2.0.9.1
- Octoprint log
- Serial Log
