I am upgrading my Ender 3 stock board to the new SKR mini v2. Wen I first hooked it up, it seemed to fry the screen (saw smoke) and no longer lit up.
I got a second one, and rehooked everything up (sans display) and now get the following error:
Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
Thanks and I really appreciate the help. Let me know if you have any ideas. Cheers.
These are the following steps I followed more or less:
- Loaded up the firmware for the skr mini v2 from here:
https://github.com/bigtreetech/BIGTREETECH-SKR-mini-E3/tree/master/firmware/V2.0
- made sure it was called firmware.bin (tried both no bltouch and bltouch)
Plugged in card to printer / turned on and waiting 10 minutes (since my screen doesn't work)
Turned on print and tried to connect. Got the error posted above.
Tried 3 different cables, one of which is known to work before, and they all give the same results.
Restarted multiple times, etc. no dice.
Yes, and no it did not solve the issue.
Complete Logs
terminal output: https://pastebin.com/D854Hhvs
serial.log (14.1 KB) octoprint.log (255.0 KB)
I have the following setup:
Rasberry PI 3b 4g
Octoprint v0.17
Ender 3 w/ SKR mini v2
Connecting from MacOS / chrome/safari.
