Check your bed, and if you have a sheet, check beneath that.
In addition, you have an undervoltage issue
2024-02-04 19:35:44,313 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
And please always post the complete systeminfo bundle. BTW: the serial.log is empty.
Thanks @Ewald_Ikemann, Wdym with checking my bed? it's working properly? Or leveling it? I'm kinda new to all this so don't really know what to look after.
'Homing failed' implies there was an issue with the probe or limit switches that were supposed to have triggered. I would probably guess it's a hardware issue, perhaps a loose connection or something.
No, I use the stock switches, but sometimes it bugs out and the stepper starts clicking loudly. I don't know why, I checked all connections, only thing I didn't look at is the motherboard. Thanks for explaining though. By the way, solved the undervoltage issue.
