Need config settings for Creality Ender-3 V2 Neo. I'm using the Ender-3 "generic?" settings, and am able to connect to the printer. I'm able to head the bed & hot-end, but when I try to print it returns an error "no printer profile selected." But in settings, the profile I set up for my printer is there, and appears selected - unless there is more than 1 place to make the selection?
As I mentioned, I'm able to heat the bed & hot-end, though the hot-end's default is 180deg instead of 200deg, so I have to manually up-it 20deg.
There are no other controls, that I can find, to auto-home, move, prepare, etc.
Reviewed multiple posts on best settings for Ender-3, but have been unable to find specifics on Ender-3 V2 Neo.
yes - printing started. I only did this a moment ago, so at this point I'm assuming it will complete.
sort of - still running the 1st print in safe mode.
browser.user_agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/109.0
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1200.0
env.hardware.ram: 914006016
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.8.6-20221018093204
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2023-02-21T13:42:58Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: True
octoprint.version: 1.8.6
printer.firmware: Marlin V1.1.6 (Sep 13 2022 15:13:53)
systeminfo.generated: 2023-02-21T13:49:37Z
systeminfo.generator: zipapi
Octoprint: Version 1.8.6
Octopi: Version 0.18.0, running on Raspberry Pi 3 Model B Rev 1.2
Running on a RasberryPi 3
