My problem is that my ender 3 V2 printer is not connecting to octoprint and it gives me the error message:
State: Offline after error
No more candidates to test, and no working port / baudrate combination detected.
What did you already try to fix it?
Test various usb cables from different devices
Logs
Performing autodetection with 0 port / baudrate candidates:
Changing monitoring state from "Detecting serial connection" to "Error"
Additional information
When performing an LSUSB, the system detects the printer with one of the usb but octoprint does not
Additional information about your configuration
OctoPrint v1.7.2
Open media vault
Ender 3 V2
4.2.2 Creality motherboard
Yes, I just added the two lines and I have restarted octoprint and the server but it still does not connect
I am using a laptop with openmediavault and docker, I have listed the users of the system and I have added all the ones that I thought could be and nothing
hopefully this helps someone, if you are using portainer to manage your containers.
You have to add /dev/ttyUSB0 as a new device in Runtime & Resources.
After this the pi was able to make the connection to the printer.
