Ender 3 V3 SE Octoprint/Dash and Nebula Pad Issues
Installed a Nebula Pad on my Ender 3 SE and it seems like it disables the serial port so I cant connect to Octoprint/Octodash that I have setup. It also seems like it disables the microSD card slot on the printer Mobo itself. As I can't get files to load
Tried Reflashing the original firmware and testing with the original screen. Octoprint immediately connected as did octodash and the SD card slot was reading standard .Gcode files from Creality Slicer. Then flashed the new nebula firmware and same issue.
Tried using a different slicer, using the slicer on the USB drive plugged directly into the Nebula Pad worked, it did not work on the micro SD card. Slicing with the Creality Slicer to the USB drive previously did not work which is why I prompted using a different slicer to begin with. Could only print from Creality Cloud at that point
I never know how to answer this question because I've never tried nor know how to run in safe mode
N/A
No more Candidates to test and no working port/baudrate combination detected > for the serial port. I've got no idea why the MicroSD Card isn't working
Running Octoprint latest software to date, Longrunner 7" TFT Screen with Octodash, Set inside a Geek Pi mini tower case with a small lcd screen showing basic network/storage information, Raspberry Pi is powered off of a Buck converter coming off Print PSU at 5.1V
Ever tried to klick the blue words?
